Why when driving my vehicle in Drive/using all 10 speeds/gears, does my vehicle transmission have weird things happening? When I drive it in L9 it works flawlessly. What鈥檚 up with that? I had the latest and greatest T-fluid installed but when in Drive the transmission operates like馃挬.
What is the latest and greatest t-fluid?聽 These transmissions are very sensitive to what type of fluid you use.聽
  • 4 weeks later...
1500 transmissions call for聽
10 speed uses Dexron ULV
8 speed uses Dexron HP
6 speed uses Desron VI聽
I'm curious too.
What are you using?
EDIT:
Should have checked before replying.
OP hasn't been seen since making that post.
Edited by redwngr
On 7/24/2024 at 4:55 PM, Fltmech said:
Probably not the transmission but the Fuel management, which is inactive in L9.
I have to agree with you. M 23 5.3 Denali at low speeds under like 35 feels like a slight transmission shudder when cylinders deactivate. If I just put it L. at that speed its usually L6. Starting in L6聽 transmission shifts smooth as silk.聽 Looks like a 3.0L Duramax is in my near future.
聽 Pasted as rich text. 聽聽Paste as plain text instead
聽 Only 75 emoji are allowed.
聽 Your link has been automatically embedded. 聽聽Display as a link instead
聽 Your previous content has been restored. 聽聽Clear editor
聽 You cannot paste images directly. Upload or insert images from URL.
