  • 3 months later...
  • 1 month later...
If the sound doesn’t happen every start, it could be:
  1. Weak Battery – Check voltage; replace if needed.
  2. Loose or Corroded Wiring – Inspect all starter, battery, and ground connections.
  3. Starter Solenoid – It may be sticking or failing intermittently; consider replacing it.
  4. Faulty Ignition Switch/Relay – Test and replace if faulty.
Check these areas to pinpoint and fix the issue.
    247.7k
    2.6m
    kalibri
    kalibri
  • Who's Online   1 Member, 0 Anonymous, 1,024 Guests (See full list)
