L87 6.2L Block failures up to 2/week at my dealer, model years 2021+. Listen for Ticks!
Just got my truck back after a block replacement at 29K miles, sharing some things L87 owners need to know. A month ago I heard lifter tap, not my first rodeo. I called around to see which dealers had a loaner, headed straight there and bent a rod about 100 yards from the service entrance. Would have made it if it weren't for a confused Prius. Truck was out for a month due to backordered blocks, visited the shop a few times to talk with techs.
Check for ticks! Shop tech said use a stopwatch:
- Fuel Pump Tick (OK): 1 tick/sec, on cold start idle, is normal and safe to ignore (loudest under rear of motor)
- Lifter Tick: 5 ticks/sec on a warm idle is usually a lifter problem (loudest on top of the motor)
- *Edit only for L86*  Vacuum Pump Tick: 10 ticks/sec on a warm idle, vacuum pump problem (front of motor)
- Quieter lifter ticks are from inside the lifter itself
- Louder lifter ticks are from hitting a rocker arm
- Higher the RPMs, higher chance of bending a pushrod. Keep it under 2,000 RPM if you've got lifter tick.
- Common cause is DFM, bad cam timing from faulty imported parts, e.g. magnetic cam timing actuator.
New L87 Blocks, Service Mgr said:
- New blocks are backordered 3-5 weeks due to high demand.
- New block quality is a gamble. Some fail out of the box, some fail later. Has had trucks with 3 replacements.
- This shop's replacement rate is up to 2/week on Sierras, Yukons, Escalades, Tahoes, etc (2021-2024)
Call around for repair (GMC, Chevy, Cadillac dealers)
- Ask about parts backorder time, got a different answer from each dealer
- Ask about loaners, few have them. Choices were small SUV or less, no hitch! Fine print limits loaners to 75miles/day no out-of-state.
- It's a complex repair, if they seem sloppy on the phone, they'll be sloppy on the repair.
After Replacement Observations (comparing old motor 0-miles feel vs new motor)
- Major difference in responsiveness. Old motor had a 1-2 second delay to feel power. New motor is immediate.
- Old motor had weird vibration, new motor has some but 80% less.
- I'm running low RPMs for 500 miles, keeping it under 2K. Don't know if it needs break-in, but will baby it for peace of mind.
- *Edit* auto-stop was disabled for the first ~50 miles
Speculation, research to prevent sticky lifters, recommendations welcome
- Gas: I run Premium, but will only do "Top Tier" stations now (https://www.toptiergas.com/).
- Oil: Switching to Amsoil Signature despite the $$$$, will still change every 5K
- Oil Filter: Switching to Purolator Boss
- Auto-Stop: Bought an auto-stop disabler to get rid of those hasty stop-restart stutters
- Randomly throw money out the window
Edited by joshhibschman
L87 does NOT use a vacuum pump so that would be an invalid symptom on an L87.
L86 did however have the vacuum pump on it.
Edited by newdude
"- Ask about loaners, few have them. Choices were small SUV or less, no hitch! Fine print limits loaners to 75miles/day no out-of-state."
Obviously, every dealership and location are different.  My dealership had no problem pulling an unsold truck off of the lot and tossing me the key to a brand new 2024 Elevation with a 8.6 miles.  I use my truck to move things and make deliveries during my days off and I didn't stop with their loaner, and I didn't try to hide it either.  I put 3284 miles on it during the just over a month that they had my truck.  Pulled my 7' x 14' trailer to Nashville and back, Baton Rouge and return twice...etc, with nary a problem in addition to more local work.  BTW, it was the 4cyl turbo and I was more than a lil impressed with how it performed.
