5.7 vs 5.3
A more fair comparison would be with a 6.0 liter.A 5.3 is not the biggest small- block and is being compared the biggest small block made up till 99.A better comparison would be with a 305 vortec which the 5.3 easily outpowers.A 6.0 is more the 350's size and outpowers it from idle to redline.The newer engines make more power and get better mileage.
One flaw in comparing a 5.7 to a 6.0 is that you can't get a 6.0 in a 1500 LD truck. Sure the 6.0 is better, but if you can't get it in every truck, it only makes sense to compare what you can. I like my 5.7 on take off and normal driving, but the 5.3 is a very nice motor once it gets rolling and on top end. But I don't drive with a lead foot, so the torque at around 4500rpm does me no good. I wish in the next GM truck platform they raise the weight limits to around 9500lbs, then maybe a 6.0 will find it's way into a 1/2 Ton 4x4/2WD. Isn't the new Titan and F150 around 9500lbs? Chris
    247.7k
    2.6m
    Fezic
    Fezic
  • Who's Online   1 Member, 0 Anonymous, 589 Guests (See full list)
