Has anyone tried to flash factory lights with this?
  • oldmann changed the title to Has anyone tried to flash factory lights with this?
FAQs:
How does the Z-Flash BCM Flasher for General Motors Vehicles work?
Using diagnostic signals, the Z-Flash Plug and Play Flasher for GM Vehicles tells the vehicle to activate the respective lights using select BCM ports. The flasher module does not rewrite computer code or affect the vehicle in any way. The codes are the same that the dealer could use to diagnose your vehicle through the BCM ports.
Will this burn my computer?
The Z-Flash Plug and Play Flasher for GM Vehicles does not put out any voltage and will not burn up the computer. It's similar to plugging a USB stick into your PC.
Will my brake lights still work?
Your brake and turn signals will override the flashing pattern. If the module is active and you hit the brakes or use your turn signal, that function will override. This cannot be disabled as it is an important safety feature.
Does this put my vehicle in reverse?
The Z-Flash Plug and Play BCM Flasher for GM Vehicles will not change your vehicle's gears.
What are the benefits of having a plugin flasher?
They are very affordable and a great way to get your POV noticed when responding to emergencies. Plugin flashers are also a great addition if you already have a lighting system in your GM. Plugin flashers require no additional wiring and can be installed in minutes!
Will this burn up my bulbs?
Like any headlight/taillight flasher it will burn out your bulbs faster than normal. Aftermarket HIDs will burn up very quickly because the ballasts are not intended to flash.
Why are my Halogen bulbs not flashing or very dim?
Unlike LEDs, Halogen bulbs require a charge up and cool down time. Because of this, it is not possible to flash them as fast as LED bulbs.
Is the Z-Flash BCM Plug and Play Flasher for General Motors Vehicles traceable?
Once removed, the flasher module does not leave any trace of being installed.
On 3/31/2024 at 1:58 AM, GETGONE said:
FAQs:
Right on!  For the refresh it uses the LCM not the BCM.  Works the same though.  Just unplug the purple connector and put the module in line.  Easy.
