No sound coming from Bluetooth, radio, & can't hear the turn signals when they are turned on
Just bought this GMC Denali 2024 2 weeks ago.   This is my First GM vehicle that I have purchased.  My new truck has had an intermittent issue when I start my vehicle the radio, Bluetooth & the sound the turn signals make when they are turned on does not work.  I have no sound from radio.  Can't hear my calls on Bluetooth.  Can't hear my turn signals when I'm making a turn.  Went on YouTube & I've seen videos to do a restart procedure on the infotainment unit.  Wondering if there has been a fix for this yet?  Also has anyone else experienced this issue?  What other problems has anyone else encountered as well with the infotainment system?
I'm curious, did you try restarting the infotainment unit? I had a Bluetooth problem too, and while a restart helped for a bit, it didn't totally fix things. What finally worked for me was disconnecting all paired devices and doing a factory reset on the infotainment system. It's a bit of a hassle, but it sorted out my Bluetooth issues in the end.
  • 2 months later...
Restarting the vehicle or resetting the informat only does a quick solution but not a solid fix. This has happened to me multiple times and I have reset the informat and restarted the vehicle, and the problem still happens. Probably say about once a month. I’m taking into the dealership next week.
  • 6 months later...
