How many miles on it? I can't hear any noise other than your loud exhaust.
Can you tell if it comes from engine bay or transmission?
Have checked the idler pulley on serpentine belt?
Have you changed transmission fluid? Have you checked transmission fluid level?
Just a couple of wild guesses on my part
Edited by rav3
The serpentine belt or one of its components could be the culprit. Check for wear, and if possible, inspect the belt tensioner and idler pulleys.
Morning noises could also be linked to the exhaust manifold. Look for any cracks or leaks, especially in the morning when metal components might be contracting.
Make sure your oil levels are adequate and consider the viscosity of the oil you're using. Thicker oil might reduce noise, especially during colder mornings.
