Good Afternoon! I’ve been experiencing several issues for quite some time and would love to know if anybody else is experiencing the same.
Back in December I had my transmission replaced. One day I took it back for a check up and I noticed that sometimes I’d put the key into the ignition but when I’d turn the key the truck would lose all power. After fidgeting with the battery terminals the truck gained power and would run fine with no issues at all. Maybe a few days later I had the same issue, but eventually the truck would start fine.
Eventually I started getting service messages that said “driver window”. I could roll my window down and the message would eventually disappear. However, maybe a week later my driver window stopped working and I’d still have to fidget with the battery cables for the truck to turn on.
i let the truck sit for about a month and noticed I’d lost all power to the truck. I inspected the battery this time and noticed corrosion on my negative terminal so I took the battery out, had the terminals cleaned and charge the battery and had it checked. The battery came back good so I charged it and reconnected it.
Now the truck turns on but with a series of service messages, the radio doesn’t work, and the steering wheel controls don’t work. The key fob buttons don’t work either but when I press them the truck does light up.
Has anybody experienced these issues before??
Sounds like you have a weak ground issue.
I'd recommend starting by checking all your electrical connections, especially those related to the battery terminals and the transmission replacement you mentioned. Since you're experiencing intermittent power loss and seeing service messages pop up regarding the driver window, probably it's a faulty ground connection causing trouble across different systems.
I suggest giving all the ground connections in your vehicle a thorough inspection, especially those connected to components like the transmission and power distribution center. Check the integrity of the electrical wiring harnesses too.
Also, getting a multimeter can help diagnose electrical issues.
    morrislh
    morrislh
  • Who's Online   4 Members, 0 Anonymous, 948 Guests (See full list)
    • If what you are doing works, keep doing it:   4LO (Four-Wheel Drive Low) should only be used in extreme low-speed, high-torque situations such as deep mud, heavy snow, steep rock crawling, or extreme inclines/declines, and you must follow the correct engagement procedure to avoid drivetrain damage. Intended Use Cases Deep mud or snow where traction is extremely poor and you need maximum torque to get unstuck Trucks Only+1. Rock crawling on steep, uneven terrain forum.fullsizechevy.com+1. Extreme inclines or declines where you need to control speed and maintain traction solutionsphere.blog. Heavy towing in low-traction conditions (e.g., deep sand, ice) carclubsusa.com.
    • Hi,   I work a steep boat landing that has patchy blacktop going down the hill and soft sand/gravel at the bottom. Due to low water levels, it's not always possible reach the blacktop. I've had to help several people get out this year already and with fall coming, I'm anticipating more. I always use 4L. There was a gentleman there today with a 2500 HD (actually 2 - him and his son both have them) and they were trying to get his son's wake boat out. This gentleman swears that you should use 4H in the soft gravel. Says he was a farmer and you always use higher gear when stuck. I was wonder what your thoughts on this are? If I'm wrong, it would be good to find out before things get busy.
    • Looking for feedback from users of roll up aluminum slat bed covers who have had it for more than 3 years. I prefer the aluminum slat style over supported vinyl covers due to security and the capacity to support a light load. The slight loss of bed opening when rolled up is not an issue. Presently have BAK Revolver the "industrial grade vinyl overlay" on mine is shrinking & coming loose at the rear and on both sides in addition to cracking at some of the folding joints. Truck lives outdoors in NC latitude. Can't justify the steep price to replace it with another one if that's the expected lifespan. Do you have a better alternative?
    • Thanks, your last sentence is the root of my problem, outdoors truck and southern latitude = UV overload. Looking at replacing with Rough Country powder coated aluminum slat roll up model.
    • I’m looking at putting a lift in my 2024 gmc sierra 1500 elevation trim, has anyone had any luck with fitting a bigger tire under the rear for a spare?? Was gonna go with a 4 inch zone lift Also what wheel and tire size setup are you all running? Wondering if I can get away with keeping around the stock size a 33 inch, and just get some new wheels to have enough back spacing then I can just keep my original spare tire I have under the truck now.
