  • Sign Up
PFTX_5.3 Build
PFTX_5.3
This truck is a 2015 5.3L Fully Loaded SLT
My goal is to build the ultimate work truck, prepared to deal with what I encounter daily, it's come a long way but I am always improving and modifying it
Please feel free to reply to this thread with any questions, I'd love to help you out
My signature picture is before the 1" lift, profile picture is after
Attached is what the truck looked like the day I bought it, I have since done:
Ranchhand replacement bumper
Tow mirrors
Full LED bulb swap
Front light bar                Toggled with high-beam stock
Front ditch lights           Toggled with high-beam stock
Yukon gear shifter
Rear spotlights with strobes
2" Leveling kit
Front 1" lift
Rear Monroe load shocks
Fog lights with high beams
Cargo lights with reverse lights
Catch can
Transmission pill flip
Range AFM disabler
Speed Turtle flasher module
Edited by PFTX_5.3
Emergency Lights, Ft: Daisy, the best dog ever
https://www.amazon.com/photos/shared/Rn1miZzkRKqZ0EClm45DHQ._j9oXP6ksclSrhZEBqBGG2
This is achieved by a Speed Turtle Engineering Module 2.0 and no-name Amazon lights off the rear bumper. The emergency lighting is a necessity due to the farm being located on a busy two lane road, I frequently have to block both lanes to allow equipnent to travel down the road.
This is how I have the bed setup. Yes, I'm a Ryobi guy, they are 95% of what the Milwaukee Fuels I have tested them against. Plus the Ryobi box system works better for vehicles than Milwaukee Packout. I'm the in-house fix-it guy, from facilities to wrenching, I do it all. This truck has it all, from almost every power tool to a 12-ton jack to a full set of sockets and wrenches complete with a beer cooler. The four boxes closest to the bulkhead building repair tools, I have a lot of duplicate tools on the truck but I like to keep a separate set of tools for field repairs because I don't want oily tools in my buildings. I can't recommend the drawers enough, I have full access to a 290-piece mechanic set and a set of hand tools without climbing into the bed, the drawers are my field repair kit. I liked the drawers so much that they are now one of the first things any of our new trucks gets. The cooler locks into the Ryobi rails by cutting the top off of their cheapest full-size box and screwing the locking part of the box to the bottom of the cooler.
Front lighting,
Yes I have a headlight out. I hate not being able to see at night this allows me to see over 180 degrees clearly lit up in front of the truck. The light across the grille is a 30in bar, the ones below the headlights are 6in bars pointed at 45 deg to bridge the gap between the front bar and the flush mounts on the side. The three lights on the front are triggered by the high beam switch in the truck using a fuse tap and a relay. The flush mounts are triggered by the fog light button using the same process as the high beams. I also have done the all-lights mod so the pictures are when the blinker stock in is the high beam position with the fog lights off. Fog lights can still operate normally unless the high beams are on.
All lights mod + cargo on when doors open,
I've got a buddy with a f150 and I like that when he opens his doors his cargo lights come on. My cargo lights come on when unlocking the truck at night due to them being tied into the reverse circuit. Because of my job, I am constantly grabbing tools and parts out of my truck when it's night but I don't lock it and unlock it every time so cargo/reverse lights don't come on. This fixes that.
Edited by PFTX_5.3
Reverse Lighting,
Again, I don't like not being able to see at night. The lights on the back bumper are the same as the ones strobing in the post above. Directly under the driver and passenger floorboards, I have 3in pods pointed about 75 degrees out, I also have the same 3in pods on the rear bedsides pointing directly out. All of these lights are triggered by putting the truck into reverse using a fuse tap and a relay.
Edited by PFTX_5.3
Auxillary fuse panel,
I mounted the aux panel on the lid of the engine compartment fuse box. I chose this location because it gives easy access to wun wires up front and to the rear of the truck following OEM wiring harnesses. Also gives easy access to the fuses I run the lighting off of. Yes, wiring is messy, what can I say, I'm a farmer. No more wiring directly off the battery or inline fuses.
Edited by PFTX_5.3
Auxillary fuse panel power,
I ran the power off of the power distribution box with 10awg stranded wire and also added a 100amp inline fuse. The wire I ran to the aux fuse panel is the red wire running along the cowl.
Edited by PFTX_5.3
Auxillary fuse panel ground,
I didn't want to run a ground wire all the way to the battery or want any wires on the battery terminals. I ran the wire to the ground strap on the drivers side cowl, about 18in from the aux fuse box, also 10awg stranded wire.
  • 5 months later...
New Tires:
I ended up going with Goodyear Wrangler TrailRunner AT 275/60R20, replacing the Pirelli Scorpion 275/55R20 that the truck came with. With all the weight that's been added to the truck the 4ply Pirelli's just weren't cutting it, extremely uneven wear, and almost bald at 19k miles. Note the rake in this picture, truck is sitting on level ground. Truck sits completely level with all the tools and equipment.
Edited by PFTX_5.3
Reply to this topic...
