My 2022 3500 has a shaking shifter as I drive. I see it out of the corner of my eye while driving.
It is slightly loose (jiggles). it doesn't go up and down to neutral and low. that is firm, It just jiggles in drive as I hit slight imperfections in the road.
Wondering if there is a set screw or something I can tighten up. I don't want to remove the boot if there is nothing to tighten
  • 3 weeks later...
First, check out the shifter area for any obvious problems. If you spot any loose screws, bolts, or clips, they could be causing the issue. Focus on the base of the shifter and gently take off the boot to get to the shifter mechanism. Look for any set screws or adjustable parts that might be making it jiggle.
Next, take a look at the mounting points of the shifter assembly. There could be brackets or bolts holding it in place that just need a bit of tightening.
