Hey all, my 22 Sierra Denali Limited with 27k miles is suddenly losing power steering. I was about an hour into a trip away for the weekend tonight and got a message that power steering assist was reduced drive carefully. I pulled over, checked around for blown fuses, and eventually the power steering kicked back on. It failed again 20 minutes or so later, again. Any thoughts?
Welcome to the forum. There is a ground strap on the passenger side in the engine compartment that corrodes causing the power steering assist to fail. I would get this into a dealer now.
This is certainly not what we like to hear, Paul Conroy.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2022 GMC Sierra's power steering system. To do so, please send an email to [email protected] with ATTN: Paul Conroy/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
  • 8 months later...
9 minutes ago, AM Frahn said:
Hello
I received this message on my 2020 Acadia--
Please advise if there is another mass recall.
4 minutes ago, AM Frahn said:
Steering Assist is Reduced
Drive with Care
This is the 2019-2025 Silverado/Sierra forum section.  Your Acadia is not a Silverado or Sierra, so the fix won't be the same.
In your case, you probably have a V6 Acadia.  If you are seeing that message, the issue isn't the steering, its the P0128 thermostat code you probably have.  Scan for codes.  You need a new thermostat and temperature sensor.  No recalls, no "mass recalls", you just need a thermostat and temp sensor.
From the GM tech note:
A vehicle may come into the dealer with a "Service Steering Message".
Upon diagnosis no codes will be found that seem to pertain to the steering system.
Code P0128 -Engine Coolant Temperature Below Thermostat Regulating Temperature may be set.
Cause
If vehicle diagnostics determine that the ECM may be reading the  coolant temperature incorrectly a "Service Steering Message" will be turned on to protect the steering gear in the event of an undetected overheat condition.
Edited by newdude
This is concerning! I received the message “Service Power Steering, Drive With Care” today on my 2024 Chevy. I had just shortly exited a sharp curve when I lost power steering. Took it to the dealership where the team is very helpful and are currently evaluating.   Although, very concerned to see these issues that potentially result in serious injury or worse.
