tpms sensors when swapping wheels
stopped by the dealership that I bought the truck from yesterday to look into getting a set of sensors.  They want $450 for a set.  That seems a bit high.  Of course they wouldn't give me the part number to look up myself.  Looking on Rock Auto and tpms.com I see 3 different GM AC Delco part numbers.  How do I determine for sure the correct ones to get?  Or will any of them work?  They're all listed as 433 mhz.  The ones on Rock Auto are part# 13528563 vs tpms.com showing 13516165 or 13542523.  Any help?
When I use my Autel to read my sensors, it shows the part number. I ordered a set of 4 TPMS sensors at my dealer for my winter tires/wheels. $220 with tax. Dealer gave me the part number and it matched the Autel reading.
Do you have the part number you can share?  Also what year is yours?
My truck is the same as my info, 2024 AT4 HD. Truck was built in Nov 2023. TPMS part number is 13542523. My Autel shows a few TPMS part numbers that were used: 13538761, 13542523, 13545366, all 433MHz. If I scroll back to include the year of your truck, also see 13530661 and 13516165.
The parts department at my dealer has no problem giving me part numbers based on the VIN of my truck.
I would verify which sensors are correct for your truck before purchasing based on the VIN. Maybe someone here can verify for you.
Edited by rjgvt
Something is seriously wrong with the parts guy at your dealer.
These are from the US Chev website accessories section
Set for 2022 2500 LTZ
Trailer tire sensors are different the the ones for the truck, so I copied both.
$40 x 4 = $160 for a set of GM ones for your 2022 2500
Even if they were going to install the sensors, $450 seems pretty high.
Edited by redwngr
I believe the Global B trucks (refreshed) use different sensors that the previous generation.
1500 changed mid 2022 model (so 2022.5 or 2022i)
I traded a '21 1500 for a '23 1500.
I kept the winter wheels I had used on the '21 --- but found I had to get the new sensors.
I'm not sure about tire shops, but at my dealer the OEM ones were cheaper that the universal fit 'aftermarket' ones they like to use.
I quizzed them if they were quoting OEM.  They looked up the OEM price and seemed surprised the OEM ones were cheaper.
(not sure if that pricing difference holds true for the pre-refresh sensors).
Edited by redwngr
You guys are awesome.  Thanks for all the replies!  Will get a set ordered and hopefully get tires mounted next week.  I’m installing Kryptonite stage 3 level kit sometime in the next few weeks.  I’ll probably leave the stock wheels on for a bit to drive around until front end settles out then get alignment.  Then the new wheels and tires will go on.
Encountered this refresh change as well when 433mhz sensors would not learn but could be read just fine. The post electrical refresh sensors are cheaper from GM OEM. It is going to be confusing as they use the same frequency unlike the previous change.
The shop I had mount my new tires had sensors for $60 so I went with them instead of ordering ones online.  Haven’t put the wheels on truck yet though, so hopefully I’m good.  They wanted truck vin for programming the sensors when they were doing sensors/tires so hopefully I don’t have any issues with them learning when I get around to actually putting them on the truck.
  • 1 month later...
finally put the new wheels and tires on.  The new tpms sensors didn't work when I first put the wheels on; truck wouldn't recognize them when I did relearn.  I had to take the truck back to tire shop with the factory wheels/tires in back so they could figure it out.  They were able to copy the signal from the oem sensors and then program the new ones to work with the truck.  Took them about 20 minutes and now all is well.  I gotta say, 35's still look kinda small on these trucks.
If you bought *actual* OEM sensors, they'd have learned with the relearn tool right away.  Sounds like you bought aftermarket clonable sensors which won't work unless they program them like you had to have done.
Right, I bought sensors from the tire shop with the tires.  I hope they hold up ok.  I probably should have just dropped the truck to them the first time and let them pull the oem sensors and install on the new wheels and been done with it.
Here's what I have encountered. I have a set of winter rims w/ Schrader TPMS sensors. After installing the set on my previous truck, 2017 Silverado HD 2500, the truck wouldnt recognise them. Dealer was unable to match them. So in the ensuing winters, I just ignored the warning.
W/ the new truck arriving, I figured I'd get things straightened out. I asked at the local garage about them busting the bead & switching the sensors to GM sensors. The young lad said, that might not be necessary. 'Bring 1 of the mounted tires and I'll check'. I did & w/ the Snap On tool, he was able to match the tire to the truck. A few minutes later I got an email from OnStar warning that the RR tire pressure was only 50 psi.
In the past I had the dealer lower the alarm threshold, so I could run my tires @ 50 psi.
Does anyone know what the OEM 'low pressure' setting is for the 2024 2500HDs w/ 17" wheels?
Edited by revrnd
Ive been planning this project for months, doing my research here. Wifes 16 equinox the tpms sensor went south. Dealer wanted $420, I found Schraeder valves for $41 each and I have a manual tire changer and the $20 tpms learn tool. Oh I forgot to mention I'm a tight wad.
wrestling match ensued. And lots of research. The tpms units i bought need programmed, (told what vehicle they are going on.
many calls later only one had the tool for schraeder. Luckily they said just pull up to door 3 or 4 an They would program them for free. WHEW! That's today's project.
the schraeder looks identical except for one molding line.
just thought I should share what I learned. Have them programmed before installing but it can be done after.
