I’m having intermittent crank no starts.  Sometimes truck doesn’t start for days.  Something is also draining batteries.  I do notice a thumping noise when truck is turned off.
Hey, did you take a look for any loose parts or a starter motor on the fritz?
The battery drain thing might be connected too. You could try a parasitic draw test to figure out where it's coming from. If you're up for it, could you spill some more details about your truck – like the make and model?
Same…crank, no start…intermittently. After sitting overnight truck then starts. Dealer says they’ve heard of this issue but to their knowledge there is no fix. Awesome.
2024 2500HD D-Max Denali Ultimate
Mat
Alaska
  • 2 months later...
I think I have it too. Dropped the truck off at the dealership yesterday after experiencing the crank-no-start problem for a 2nd time in 2 weeks. They won't even look at it till April 22nd. Haven't had battery draining issues though.
Edited by rdonarski
More information
  • Sad 1
