2024 L5P - Loose Mirror - Low Speed Rattle - Boost Noise
1) Loose Drivers mirror, when hitting sharp bumps it looks like the mirror is going to fall off.
2) Low Speed rattle coming from passenger side, only occurs from speeds between 50 - 60kph. Plastic or thin metal tapping/flapping sound. Kicking truck into neutral and changing RPM does not effect the noise. I have taped off all exterior panels and inspected. Starting to think its drivetrain..
3) Started yesterday - Boost tube type medium/higher pitched growl noise around 2300RPM under load. Sounds to be coming from passenger side. I don't believe its related to the #2 issue.
