Programming a Key fob for a 2021
I just bought a 2021 silverado which had only one key fob. I bought 2 new ones and can not get them to program.  I have watched several youtube videos on how to program new key fobs. When I try the first step and put the key in the drivers door and turn it 5 times to the left, the display does not acknowledge anything.
Anyone have any ideas?
Are you in Canada?
Regardless if you have a keyed ignition, or push button start, if you have only ONE working key/ fob then you need a subscription/ access to Techline Connect OR take it the dealer or shop (capable of dealer-level programming) to program a new key/ fob to the truck. It takes about 20 minutes and involves a few prompts and button pushes if you're doing it yourself. I had to do this on my '21 since I bought it CPO and it only came with one push button start fob. If you have TWO working keys/ fobs already, then you can easily add a third by just doing the quick ignition cycling procedure.
