Radiator replacement at 90k miles
hello fellow GM drivers. happy holidays.
I wanted to ask Has anybody had their radiator crack on their 19+ Sierra Silverados. Mine cracked on the driver side plastic side. It bulged outwards.  I did do a coolant drain and fill not to long ago. Perhaps I didn’t bleed the air enough and over pressure caused it to crack. Found this failure really strange. If anybody has any knowledge on how to remove It. I’d  appreciate it. I managed to get some some JB WELD. On the crack without removing it or sanding the plastic. But  it lasted 5 days because I didn’t prep it and sand the surface because I couldn’t reach in between the condenser enough. So the epoxy cracked and leaked ……
Already have a OEM unit being shipped. Just wondering if anybody had experiences removing this radiator on this body style. Because it looks over engineered like All vehicles nowadays. Have to remove a lot of plastics.
 It’s a 2019 Silverado CC Z71
5.3 8speed
OG owner.  keeping this bad boy  forever.
the uploaded image was found on Reddit from Some other truck 19+  owner. I have the same EXACT. Failure location. Strange.
Edited by 11bravoZ71
5.3 8speed
Sh***y plastic side tank on the radiator. I've seen a lot of them leak. Never done one on a T1. This is not unusual. They usually leak between the tank and radiator core.
 To those who might need to someday replace their radiator DIY on the 19+ GM trucks.  I Got the radiator installed. I watched  YouTube videos of the previous body style 14-18 trucks. And the process was very similar if not very close. A 3 hour job but in retrospect fairly easy. this video was spot on. Even though it’s the previous body style. It guided me through till done. I did have to remove skid plate to make the job easier. Just do it.
Attached I have my cracked crappy JB patch on the old radiator  LOL.
On the new radiator I lightly sanded the same area and applied JB WELD. As a preemptive move because it seems these radiators crack in this exact spot for some reason.
