2024 Custom - Driver-side Rattles
Hey all, I'm the type that can get annoyed by rattles. Especially when they are quite loud. I have 2 right now that I'm dying to get fixed. One the dealer can't find and the other they said was "normal". Just trying to get your thoughts on it, and maybe even a solution.  I have tried searching the forums with no luck. I'm not always the best at finding things though.
1st. The first rattle comes from under the dash on driver side. It ONLY happens after first starting, when I first drive out of my drive way. Two things make it happen... 1st, if you slightly press the brake pedal and let go right away, it's a clicky/rattle sound, or when I drive out of my driveway over the curb/threshold onto the road. It sounds almost like the steering column clicks back and forth. It literally won't do it again once I start driving. When I lightly tap the brake pedal to make it happen, I can tap it a couple times making it happen, then by the time I'm on the road it doesn't happen anymore.
The dealer said this is something to do with the ABS system doing a check. He said he's had lots of complaints that sound the same. This is my 30th vehicle (for real) and I've driven tons of HD trucks for work. I've never had this happen. It makes my new truck sound like garbage. Anyone come across this?
2nd. The second rattle is behind the driver dash as well. To reproduce it, I have to go over a medium bump at 50-60km/h (30mph?). It especially happens when the driver front tire hits a bump where the weight of the truck comes off it for a split second. Almost like a bad strut. Its like a hollow knocking type rattle. I thought I found it when I giggled my hood release, but after holding it while hitting those bumps, realized it wasn't it. Anyone experience this? My dealer hears it, but can't find it. Getting really annoyed.
Thanks.
First one is probably normal.  ABS self test is likely.
Second one.  Could be a loose coolant reservoir.
PIT6058: Rattle / Clunk / Tap Noise From Front Of Vehicle - (Sep 14, 2023)
Condition
Some customers may comment on a rattle / clunk / tap noise that seems to be coming from the front of the vehicle.  The noise may sound like it is coming from behind the IP dash, door, body, suspension or under hood areas.  In some cases, this noise can be very hard to duplicate and/or locate.
Cause
The cause of this concern could be one of the engine coolant reservoir/ surge tank mounting bolt(s) being loose, example shown below.
Correction
To correct this concern, inspect all of the engine coolant reservoir/ surge tank mounting bolt(s) for being properly torqued and tighten any loose bolts to 9 Nm (80 lb. in).
Condition
Cause
Correction
Thanks for the fast reply. I'm sad to hear the first one is normal as no other vehicle I've had or driven has done it, so poor design it seems, but I can get past this one since it goes away after a min.
I forgot to mention, my dealer tried two things to fix the other one. They tightened the coolant reservoir (which actually was loose). They also tightened the license plate bracket, fastening the top to the bumper. It was rattling and the paint on the bumper was wearing off at the top of the bracket where it had been vibrating. Neither of these got rid of it unfortunately.
I also just remembered one more aspect. When it's raining or the roads are really wet I tend to not hear the second rattle. Also, I just did an 1100km trip and I haven't heard it the two times I've driven since. Right before the trip it was crazy obnoxious though and getting worse. I did drive through a LOT of rain on the 1100km drive.  Not sure how that could effect it?
I saw one post on a forum where a bolt was loose under the windshield wiper cowling. Wasn't sure if that could be my rattle.
The second one sounds like the hydraulic steering rattle these trucks have.  It is worse when it's cold out due to rubber in steering system getting stiff.  The steering cooler is rattling due to not enough rubber in the return line to dampen the pulses in steering system from having tires hitting a bump.  There is not much the dealer can do.  I have seen making the supply and return lines not touch at gear helps and also making sure the steering cooler can move freely helps but nothing kills it.  You could remove the cooler or hang by bungy cords to test the theory.
I have heard the first issue as well and it seems only to occur after an overnight soak and seems worse in cold temps.  It seems to be tied to brake switch releasing the shift lock to allow shifting from park.  I don't know of any known fixes for this issue.
I think both of these are characteristics of this generation of truck.  This generation of truck when they tied the front end sheet metal to the cab has created a noise path straight up the steering column.  There are steering and brake systems noises that are more noticeable than the pre 2020 trucks that use basically the same parts.
You won't like my answer but you probably are going to have to learn to love it.
#iworkforGM
#iworkforGM
Wow, thanks so much for the insight.
The first issue definitely sounds like it's tied to the shift release mechanism... the click you get when you press the brake and it allows the shifter to move.
Regarding the 2nd issue, it kinda frustrates me, but I'm at least satisfied in the sense of, "I'm not crazy, there actually is an issue". I've been searching and searching and can't find any answers, so thanks for explaining.
Really appreciate it, even if it wasn't a solution.
#iworkforGM
Could the cold weather power steering hose kit that is available cure this? I've always wondered what gm had this kit for?
No, there is a different fluid and different hoses to prevent them from bursting in extreme cold temps when you brake and turn at slow speeds.
#iworkforGM
#iworkforGM
I live in Vermont, what is considered extreme cold temps?
