Heated Steering Wheel..... HOT !!
21GMC
I recently traded in my 2021 for a 2023 model 1500 Sierra.
One thing I have noticed immediately is the heat my refreshed Sierra's steering wheel is putting out.
It is significantly hotter to the touch than my previous truck.  Infact, I turn it off fairly quickly after starting it compared to the older gen which I just left on continuously.
Anyone else have a similar experience? Not really a complaint but certainly a noticeable difference for me.  Heated seats seem roughly the same as before.
I've noticed three things in particular about the heated wheel on my '24...
- It gets noticeably warmer overall.
- Anywhere that you hold your hands at least briefly seems to not get "as hot" as if you didn't touch that area at all while it's one. As I drive away from the house and make a handful of turns, I find that the temp of the wheel sort of "evens out" at a more moderate temp which is quite comfortable.
- There are some definite "dead spots" where the wheel is quite cold still.
Very similar here. I haven't had it on long enough to see if it evens out but shall try,
At least i know its operating normally now !!
kinda funny, owning more than a few T1 designs the heated wheel was bit different in all of them, believe my sierra was the warmest though, I dont care too much but have noticed
I've also noticed the steering wheel heat increase in the 23 vs the 21.
Seats also heat hotter and faster.
Truck arrived late spring. I'm wondering about how the performance will be in Jan/Feb.
Not sure about all trims but this truck they automatically turn on when the truck is started on a cold day.
The '21 didn't do that. (like they have for many years, the worked under remote start, but needed to be turned on again after getting in and enabling/starting the truck)
Wife drives a 2020 Acadia Denali.  It had the automatic steering and seat heaters.
I found it surprising that the feature wasn't on a '21 Sierra Denali.
The '21 didn't do that. \
Yes, my 21 didn't do it either.
My wife's non GMC branded SUV from 2013 has automatic steering and heat warmers when the temperature hit below 40.
I always thought that was a neat option that we had not seen since.
Edited by 21GMC
I haven't kept mine on long enough to find out how warm/hot it gets. Once comfortable on my hands I turn it off. The seats get warm enough for me to turn off, too. The seat rarely turns off on its own. I don't like wearing gloves driving so the heated steering wheel is a must since moving north. I have supercruise so it takes a bit for the top of the wheel to warm up.
Setting in the infotainment, I believe. The '21 referred to it as "Auto Heated Seat" and they would heat according to the cabin temp settings. This is how the ones in my '24 seem to work as well... As the cabin temp comes up, the heated seat setting tapers down until it finally turns off.
In other words, it appears your '21 should have had it but it may have been off by default..
Hmmm.
I am/was thinking that "Remote Start Auto Heat Seats" was the setting available on a '21.
26 minutes ago, redwngr said:
Hmmm.
Not sure. Attached is in the 2021 manual. It tells you to turn it on or off in the personalization, but the personalization section of the manual makes no mention of this feature - only that for Remote Start.
Edited by ember1205
And from the info starting at page 131 -- the only thing I could ever find was the info about 'Remote Start Auto Heat Seats'.
Yupp -- I might have missed it in the manual.
Yupp -- I might have also missed it working the settings on my 2021.
With it working that way on the 2020 Acadia, I did want to get it working on the truck.
Been using remote start auto heated seats/mirrors/wheel/defrost for years.
