Vibration help?
Thanks for allowing me to join for help. I have a 1990 3/4 Ton regular cab 2500 2wd with a TBI 5.7 Liter engine and a TH400 Transmission, so no OD. The Problem: I get a rhythmic vibration from 30mph on up. It might be a little lighter under acceleration but always there. Probably most pronounced between 45 and 50 and maybe worse under deceleration. I have replaced center and rear joints the carrier bearing. Had the driveshaft balanced, and I just paid a shop 800 to replace the Torque Converter because they said that was causing it. I am trying to figure out where to go from here. The only slack I can find is in the tail shaft of the transmission but not sure how much is normal and shop said that would not cause it. Pinion feels tight and I just replaced rear axle seals and everything felt and looked good in the rear end…any help would be appreciated.
Welcome to the Forum! Any vibration in neutral or change shifting to neutral while it's occurring? Was there any change at all after doing the converter? Sounds like the T converter, wonder if you got a defective 1
