2020 Passenger Door Lock not working
Won't work when pushing the button on the outside of the door?
Won't work when using the inside passenger door button?
Won't work when using the driver door inside 'unlock'  button?
Won't work when doing double press of drivers side outside door handle button?
'Locks' setting in personalization is set for it to 'unlock all on first press' or 'drivers only' on first press?
How about when using fob -- one press and / or double press?
Once the button is down the only way to get it back up is pulling the inside door handle. If the button is up and I press lock on the door pad (any door) the truck will lock but the lock piece stays up.
The times that I have seen it work have been sporadic.
It does not lock or unlock from the fob at all. I have not thought about checking the settings for locks.
Lock actuator is part of the latch assy. Fix it before it stops unlocking totally as it can be a bear to open the door to get door panel off and get to latch bolts inside the door jamb.
Common GM thing, I've had to replace them in GM cars in the past. With the auto locking they get over used IMO.
On 10/14/2023 at 6:03 PM, SilverBulletBoss said:
Door lock on 2020 TB has recently stopped working on front passenger side. It will unlock about 10% of the time. I thought it was a battery issue, I ended up getting a new battery (had a bad cell so it wasn't a total waste). Door lock is still not working. Any suggestions? TIA
This is certainly not what we like to hear, SilverBulletBoss.  Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your 2020 Chevrolet Silverado's passenger door not locking up. To do so, please send an email to [email protected] with ATTN: SilverBulletBoss/GM Trucks in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s Privacy Policy, please visit https://www.gm.com/privacy-statement.html. The information you provide may be monitored and recorded and is subject to the GM Privacy Statement.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information.
www.gm.com
