2024 LED replacement bulbs for taillights and interior domes?
Has anyone successfully found LED bulbs that wont trigger the bulb burnt out message? I ask because I tried a handful of bulbs with my wife's '23 Suburban 3.0L and none of the bulbs (even with "built in resistors") worked without messing up the entertainment system (bizzare result!) and a bulb message. I'm looking specifically to get more lumens out of the back-up bulb really on both setups.
Also, can some one point me out to a thread or aftermarket parts on how to replace/upgrade interior overhead LED lighting? The only thing I found was the floor lighting thread. The Chevy LED dome and map lights are PATHETIC both in the 2500 and Suburban.
Thanks!
Edited by davidm767
So I found a quality LED tail light replacement that works great. The LASFIT 912 921 LED Bulb Reverse Light, 6000K White Canbus Error Free T15 W16W (https://a.co/d/ecuXYmf) on amazon is a drop in LED replacement to the incandescent W16W bulb. It had no problems with the DIC or Entertainment center that my wife's Suburban did when I tried finding alternatives for her ride.
Edited by davidm767
  • 3 months later...
Just to clarify, did you replace your 24 Silverado 2500HD tail lights with the Lasfit LEDs in your above post and no issues?
Correct. I've been running LASFIT for several months now on my 2500 with no issues.
Thanks @davidm767!
Another question, I’ve only seen people change front signal light bulbs with LEDs, what about the rear signal lights, are they the same bulbs as the front signal lights, or are they part of the tail lights?
Edited by Rich.Dev
