2001 Chevy Silverado 2500HD Tire size for 20x10 rims
What size is on it currently?
I ask because it's not always about tire size. A smaller tire can still rub if the offset of the rim is what is causing the tires to rub.
Edited by CamGTP
You are kinda limited on what you can do.
315/60's are basically a 35in tire that is 12.5 wide. You could switch to a 35x11.5 tire to lose width or you can go down to a 34in tire with a 295/60/20. You will lose height and width which will give better clearance.
