Low Oil Pressure
Did you change the screen under it?
How often do you change oil and what oil do you use? Did the drop happen overnight or over months, years? :dunno:
You own this from new?
Have you recently changed oil weigh or grade? Different filter manufacture or grade with the same manufacture? More detail please.
Have your dealer do a test block pressure survey before you panic.
Edited by Grumpy Bear
Agreed, completely normal for a 5.3/6.2 LT engine.
I run low 20's at hot idle and it runs like 36-38psi cruising at 60-70mph. Theses are computer controlled oil pumps, it doesn't require a lot of pressure to run fine.
