truck bogging down around corners, dyno tune
Hello all,
I have a 2018 silverado crew cab 5.3 with headers and dyno tune, and the oddest thing happens when i'm turning a corner.
it seems to almost be stuck in a high gear after turning a corner and upon accelerating the RPMS actually go down as well as lackluster performance and poor speed...  if I jam on the gas pedal it will down shift but at really high RPM which seems completely out of line.
Versus after turning a corner, accelerating and the RPM going up and a gradual transition to a higher gear.
Please advise, thanks in advance!
19 minutes ago, Ryansal said:
Hello all,
They do this stock.  I've not figured out if its torque management or if its a transmission issue like converter slip or pump low pressure/failure.
Edited by newdude
True
mine does similar “falls flat” when coming out of a slower turn. Almost as if it s confused on what gear it is supposed to be in.
stutters then finds a gear.
Not sure if this is fixable or characteristic on the drive train. ??
Hi all, It was suggested that I add some transmission fluid, after checking my fluid my "cold" level was fine but my "hot" level was low.
I added about half a quart and It seems to have improved, albiet I did this a few days ago only, will give updates.
Wouldn't think transmission fluid would be on the lower end at 32k miles.
