EdGein72 Posted August 22, 2023 Share Posted August 22, 2023 My 09 Sierra 4.3 won't crank. I turn the key and nothing. I checked online and youtube said try finding and swapping relays. Didn't change. Another said try disconnecting the BCM and grease it and reconnect it and that didn't work. There is no click, the truck doesn't even try to turn over. Everything lights up like normal on the dash. The radio works fine. I even tried jumpstarting it and still nothing. This has never happened before. I don't know what else to try except take it to a shop. Things were so much easier before all this computer crap. Probably the simplest thing but I don't have a clue. Any incite would be much appreciated. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
CamGTP Posted August 23, 2023 Share Posted August 23, 2023 Take the battery out and go get it tested. 1 Quote Link to comment Share on other sites More sharing options...
BarryKH Posted August 23, 2023 Share Posted August 23, 2023 Disconnect the battery and leave it for 30 minutes or so. Reconnect it and try to start it. Quote Link to comment Share on other sites More sharing options...
swathdiver Posted August 23, 2023 Share Posted August 23, 2023 Maybe it's an old school failure, the starter solenoid died? You can throw parts at it or put a Tech-2 on it and find out in moments what is wrong. Quote Link to comment Share on other sites More sharing options...
asilverblazer Posted August 25, 2023 Share Posted August 25, 2023 Make sure the engine is grounded well to the chassis/battery. Quote Link to comment Share on other sites More sharing options...
SmokChsr Posted August 26, 2023 Share Posted August 26, 2023 Don't forget the silly things, make sure the transmission knows it is in park, also try starting in neutral. There are also anti theft circuits that may cause this, be sure to lock and unlock with the fob. Quote Link to comment Share on other sites More sharing options...
