Side Mirror Camera Intermittent Failure
Several times the driver side mirror camera has not worked, and the surround view displays a black block all the way down the left side of the truck.  When the camera does work, it flickers between an image and a black block on that side.  Has anyone experienced this and know what the fix was?
I've already had the camera module replaced twice, and a tailgate camera replaced once for the black screen and red exclamation point when putting it in reverse, and now this.  Between the parking sensors randomly disabling themselves and being unable to toggle on or off via the switch, repeat camera issues, and repeat check engine lights for misfires with 5 attempted repairs, it's sure frustrating.  Are all these new trucks just destined to have electrical gremlins now?
  • 3 months later...
Gremlins comment, pretty much.
GM has real bad EMC/EMI issues these days and it's hard to say if its related to that or its bad signal to noise ratio for the camera feeds in general.
Of course software on the modules could also do this and drop out but likely you have a deeper issue than just the camera module itself.
Might need to replace/reflash the main ECU that takes all those camera feeds together or play around with grounding the coax camera lines to the chassis at the ECU itself.
Not sure where they go to or what the ECU is called but the same methodology applies to all the new hot garbage GM pumps out on any vehicle architecture.
the biggest problem with all manufacturers is they keep adding more computers but they don't update the software to diagnose the systems. i feel sorry for some of the techs today because they can't do their job without the right equipment. so you bring your vehicle in when it is still under warranty and first thing is to fire the parts cannon and hope for the best. or they have to totally disassemble your vehicle in hope of finding a problem. your mirror problem is probably a connection problem but in order to find the problem your rear seat has to be removed or your door has to be taken apart. when you are out of warranty you are sol. now a days you have to know how to use an ocilliscope
  • 3 weeks later...
I'm having same issues with my mirror camera sometimes goes out then comes back on .that creates a problem with LKA it does not work with camera out so dealer thinks bad camera but I'm thinking some kind of computer problem or bad connection since it's intermediate it's 2019 sierra denali I have 65 k miles bought last year and purchased best 5 year warranty for coverage problem is I made appointment but it started working again dealer said can't fix under warranty if working when I bring it in would this be detected with computer reader not sure what to do any suggestions would help thanks jeff
  • 4 months later...
Can someone tell me the best way to take the bottom housing of the mirror off so I can cleans d seal the coax connection. I notice that it blacks out much more after I’ve gotten a lot of dust and water I side the cover. It seems to just be the driver side and clears up with a clean dry truck.
I have had the same issues with my 2019 AT4. My cameras tend to go out when it rains or I take the truck through the car wash. It seems like a lose connection somewhere.
  • 1 month later...
Has anyone solved this issue? Just bought my AT4 this weekend. It was fine when I bought it and for the first few hours road-tripping home, drive through some heavy rain, and my drivers side camera looks just like it does in that picture up there. Came back on yesterday, and today it’s doing the same thing again.
We are sorry to hear you are facing these concerns with your vehicle and would like to take the opportunity to investigate further for you. Please send us an email to [email protected]. Be sure to include your Username and Forum name in the subject line with additional details. We look forward to hearing from you.
  • 3 months later...
Truck went back to dealer last week for the same problem again.  Dealer said they were replacing the left, right and rear camera harnesses but GM only approved the rear harness for replacement.  They claimed to find a short in the rear camera harness coax and the rear camera (that’s been previously replaced already) had an internal short in it.  Not sure how that makes the driver side camera go black or flicker but this was their solution.  They dropped the spare assembly and disassembled the whole tailgate to fix.  Time will tell if it rears its head again.  This is repair number 6 or 7 to the crappy HD surround vision system.
  • 1 month later...
I bought my 2022 Silverado 1500 brand new in summer of 2022 and this issue began happening almost right away. It's been to the dealer over five times. One visit I had to wait several months for a wiring harness to come in that was on galactic backorder. This didn't even fix the issue when it did finally arrive. Currently today my dealer is STILL working with GM to diagnose the issue. Who knows when, or if, it'll ever be fixed. Anyone experiencing this issue, good-freaking-luck!
  • Sad 1
To me its clear GM has an issue with reliable electrical systems if it takes this many repairs and they keep throwing different parts at the system.  Since our last camera system repair we haven't had a camera failure yet, but the parking sensors have failed for the fifth time and will be going back for repairs at the next service visit.
