Ac not blowing cold.
Added Freon Schrader valve bad replaced it. Now it blows cooler than outside but about it. I turned on vent no AC hot air comes out turn to recirculate and it’s cool.
not sure to try next. When I get off work will check the cooler to see if it’s dirty.
Did you evacuate the system to get all the air out? Vacuum down the system. Make sure it holds a vacuum for at very least ten minutes.
Never worked on ac before. When I took the cap off the low pressure side all the Freon came out. Replaced the valve and filled with Freon. All I have done at this point. Will try more when I get off work.
thanks for the input
