No Replacement for Lower Ball Joints on Trailboss
I installed the Ready Lift SST leveling kit on my 2019 Custom Trailboss about 8 months ago and have recently noticed some rattling when going over bumps. After checking the torque on everything and finding that nothing was loose, I did find that there seemed to be some wear in the tie rods and lower ball joints. I decided to replace the sway bar links, tie rod ends, CV shafts, and lower ball joints. I ordered some lower ball joints which I believed would replace the old ones. However, once I removed the lower ball joint on the passenger side, I found that the one's I ordered were not the same and have now discovered that no one is making replacement lower ball joints for the 2019+ trucks, so it looks like I'm going to have to order a whole new lower control arm. I suppose it's easier to just change the lower control arm but replacing just the ball joints is about four times cheaper.
5 hours ago, Bikerjon said:
How much lift did you install and how many miles on your truck?
I installed the Readylift 2 inch lift on the front in addition to the factory 2 inch lift. I've got about 85,000 miles now.
Update: I have replaced the tie rods, CV Shafts, sway bar links, and the passenger side lower control arm. Whatever rattle was there previously when going over bumps is gone.
  • Thanks 1
  • Haha 1
Glad to hear it.  I haven't yet replaced the LCAs, was it a difficult time to line them up at the right angle before snugging the bolts?
  • 4 months later...
Do you happen to have the links for everything? I have the same problem with my drivers side after installing the same kit.
