2023 AT4X, A/C starts on high then about 12 seconds in cuts to low automatically.
I’ve got a 2023 AT4X and when I start the truck up, I may already have the A/C blowing full speed and about 12-15 seconds in, it automatically turns to low on the fan speed.
I do not have it in auto mode, temperature setting is at “low”.  Recirculation is set to on.
It does this every single time. It has to be something minor but I can’t figure it out. Being in Texas it’s hotter than you know what. I Get in, turn AC up full blast and then 12 seconds later it turns down then I have to press the button to turn the fan speed back up . Only does it after starting the vehicle up.
Anyone have any ideas?
Thx.
It's an issue that has been discussed here, after the last update this issue started to happen to some of us. No fix yet that I know of, the way I get around it personally is hit the mute button on the steering wheel, the HVAC will start to blow normally and then hit the mute button again, only takes 2-5 seconds at most.
Same issue with my 2023 LT. Took it to the dealership and of course I got the usual "it functioned like it's supposed to and it's not throwing a code so there's nothing we can do." I've found switching it back to manual and then back to auto starts it back like it's supposed to.
