Sorry if I missed this topic - I think my AC drain is clogged/partially obstructed.  Sometimes I see fluid draining after running the AC, but often I don't.  No issues with water anywhere in the passenger side compartment, but I am getting the musty smell.  I removed the right front tire and searched, including removing a heat shield next to the exhaust and still nothing that was visible.  Does anyone know where this drain tube exits the underside of the vehicle, and/or is there any way I might be able to blow it out from the evaporator end?  Of course I'm sure that would involve taking the front half of the truck apart!  2020 Silverado 2500.  Thanks.
  • 1 year later...
On 7/4/2023 at 5:54 PM, newdude said:
Hello do you know where the drain is on a 2020 Blazer?
Behind and just below the right rear cylinder head in the firewall.   Above the transmission.  Rubber grommet with a diaphragm looking end in the center of it.
    247.7k
    2.6m
    Joe Upton
    Joe Upton
  • Who's Online   3 Members, 0 Anonymous, 979 Guests (See full list)
