My iPhone does not want to automatically connect to the onboard Wi-Fi on my 22 Sierra 1500 Limited.  When I tell my iPhone that the network is available it will then hook up automatically. But no connection until I let it know the network is there.
Am I missing some setting in the truck or on the iPhone?
Suggestions welcome.
1 hour ago, cef2lion said:
My 22 Refresh does the same. I have my iPhone set to reconnect after 1st connection. Every time I start the truck I have to manually connect to the truck SSID. I don’t have that issue with other WiFi connections I have. I have found no fix.
Did you select Trusted Device in the settings?
Same with my '21.  When I first got it(and whatever iPhone was current at that time) the iPhone would reconnect to the truck WiFi when it would start up.  I'm not sure when it stopped.  Annoying, but not the not of the world for me.  If there is a fix, I'll gladly try it out.
15 hours ago, Tom73 said:
Did you select Trusted Device in the settings?”
Where do I find that setting?
I think this only applies to refresh 2022s and 2023s
Edited by dieselfan1
22 limited and 22 refresh or just the refresh trucks?
OP has a 22 limited.
Any other thoughts?  Couple of days ago it automatically connected but that is the only time in the last week that it has preformed like it should.
