Always on USB Power?
Interesting.
My 21 has 12 v power ports. (and the 120V shared 400W outlets)
2023 owners manual shows 12v power ports.
I have a '23 being shipped.  I'm curious to see if it has 12v port(s).
13 hours ago, redwngr said:
Interesting.
No standard round 12v ports in my '23 LTZ Z71 crew. Just USB in dash and console. 120v in console and bed. Has technology package. Running my V1 off the Savvy adapter in the OBD port.
Edited by repairman54
Decided to see if there was any info about this in the fleet order guide.
It shows the 12V outlet is only installed/available on low trims.
On sierra
First column is the 'pro' trim.
On Silverado it comes on the WT, Custom and Custom Trailboss
So it would be in the Owners Manuals -- and not be on the high trim trucks mentioned in other posts.
Perhaps also explains the OM section discussing fuse location changes -- and the lack of available connection on higher trims that will not have the 12v pot.
Guess I'm won't be running the 12v cooler with the new truck when it arrives  🙁
Edited by redwngr
On sierra
Yes, I was pretty shocked on my ride home and realized I had no 12v port. Bizarre.  At least there is a 120v outlet that perhaps can be used for the cooler?
He could, if'n his cooler only pulls a tad over 3 amps. That 120v receptacle is about as worthless as t!ts on a boar.
Edited by gemarsh
Anti-spelling
  • 1 month later...
I assume nobody has found a constant power source on from the passenger side box?
I would like to install some extra footwear lighting on my dad's 2023 LT silverado. Using the X1 BCM connector's pin #1 12v as a trigger for the relay, and power the lights via the F28. Avoiding running a wire from the battery.
I put my meter lead down the empty fuse hole to the circuit board, while the truck was off, and was able to see 18v on the meter.
The F28 socket on the circuit board DOES get power constantly.... but the prong to plug something in to it is not present.
  • 4 weeks later...
19 hours ago, Jay dog said:
This sucks, I can't get my 2023 silverado to charge my phone when the truck is off....now I wish I kept my 2022....no way I can tell to make the 2023 charge when it's off...damn gm...always gotta screw ****** up.
I ended up mounting an auxiliary 5v port with full time power.  Works great.  But yes, it's extremely frustrating they took away the 12v outlet, and the ability to select full time power with the F27/28 fuse.  Dumb move.
  • 6 months later...
Looking at this post(kinda old). I'm in the same boat. I want power full time to an USB port or something. Every other Chevy I've owned has had that. I have a 23 custom refresh. And they certainly got rid of that extra prong on f28. This suck cause you could have fulltime power to your socket and you could tap into that extra prong with a spade connector to power add on accessories with switched power. It was perfect cause it was set up for 50 amps. Also, my 23 does have a 12v cig lighter jack.
  • 4 months later...
Has anyone tried jumping the circuit on the K2 relay?  ie putting a jumper wire across the normally open circuit .
Edited by Mayo
So I tried jumping K2 port 30-87. With the key off I had power to fuse 27, but no power to usb outlet.
I am thinking it is going to be a software fix.
The F27 / F28 thing is so you have a choice -- RAP or continuous
If you want the power to supplied as RAP use the default -- F27
If you want to switch it to continuous power -- pull the block and put it back so it uses F28.
F27 and F28 power the same places, so if F28 is powered, the RAP function cannot shut those locations off.
  • 4 weeks later...
Im having the same issue.
Why cant I just add a prong with constant power to where it's missing on my 2023? Shouldn't doing that send constant power to all USBs all the time?
