2018 Silverado 1500 5.3 Gas P2101 code, Stuck in Limp mode
Hello,
I'm looking for assistance troubleshooting a P2101.  When it first happened, I didn't have a scanner but the truck went into limp mode.
I unhooked battery and it started driving normally for a few miles, then it happened repeatedly. After many battery resets I finally got it home.
Scanner showed code P2101. I checked connections at the throttle body and the gas Pedal.
I replaced the throttle body with a new one, no change.
I have a new gas pedal arriving tomorrow and I have checked and cleaned all Ground connections I could find.
Another thing to note is that will limping home and hooking and unhooking the battery, the positive battery post and fuse plate felt warm/ hot almost.
Question, Is there a procedure to get the truck out of Limp mode?  Unhooking the battery no longer helps.
What else should I look at before going to the dealer?
I found bulletin number  18-NA-037  that may be related to my issue. DDOP Software anomaly that will set the P2101 code
Thanks
Dave
I ended up taking it to the dealer. I was thinking it was an ecm issue.
  $550.00 to diagnose, replace the electrical connector at the throttle body and  relearn/ program etc...
Without re-installing the old throttle body, I wont know if it was the wiring all along.  But I'm not going to mess with it.
Thanks for the response.
    247.7k
    2.6m
    Tony Best
    Tony Best
  • Who's Online   1 Member, 0 Anonymous, 885 Guests (See full list)
