Oil change question with on 4WD
I have a 2022 4WD Silverado that I am fixing to do the first oil change on and I need to know if I have to put the transfer case into neutral to roll it off the ramps?
The truck is too tall to reach the oil filler until I back it off the ramps...on my 2WD 2016 I just turn the ignition to accessory then put the shifter in neutral and roll off.....can I do that in the 4WD or will I need to put the transfer case in neutral as well?
Thanks!
11 hours ago, jaxcam02 said:
If you have the electronic shifter your not going to be able to shift into neutral without starting the truck.
I have not tried this, but this is the video I watched that shows them putting it in accessory mode and changing it.
2 minutes ago, redwngr said:
Sounds like you need lower ramps and/or shallower pan to catch the oil
I can't get to the oil plug without the ramps or I wouldn't use them at all....would be a lot simpler without them.
The oil cap is really far back on the new truck, it is a long reach even without it being on ramps.
Fun fact.  If you have regular 4x4 and not Z71, you have the single speed transfer case which does not have a neutral position.  Just 2HI, 4HI and 4AUTO.
Being you've got a RCSB, it is possible to have ordered the 2 speed case, but not sure if you did or not.  Otherwise they are just a single speed case, no neutral.
Edited by newdude
That's me!
This is the first time I have ever had a 4X4 and it wasn't a Z71.
Reckon I don't have to worry about neutral...lol
Thanks!!
Thanks!
Why not just lay on something to elevate you so you can remove the oil filter?
I can get the oil filter off easy enough, but the oil plug is almost in the center of the truck and I don't have enough clearance to reach it without raising the truck some.
No I meant the actual transmission. Not the transfer case. But that would be for the new body style console shifter.
Edited by jaxcam02
    247.6k
    2.6m
    Goat House
    Goat House
  • Who's Online   4 Members, 1 Anonymous, 316 Guests (See full list)
