Help with transmission.
94 K1500 with 454 swap, Holley sniper EFI and hyperspark distributor, original 4l60e rebuilt 200 miles ago, truck runs but not shifting in drive, stays in 3rd gear. Plugged obd 1 in and it says park/neutral when shifting. Speedometer works so getting speed sensor data. Checked power and ground but can't understand how the trans gets rpm data. The sniper doesn't have a trans adapter but trying to figure out a way for the trans to see rpm and shift correctly.
