  • Sign Up
2020 Silverado sway bar hitting CV axle
Hello all, My Sway bar was hitting my CV axle, as the title says. So I crawled under some trucks at the dealer to see what stock trucks are like and it turns out that the new TB/AT4's have longer end links then my 2020 TB. The new end link has a 3 inch rod vs the 1-3/4 inch OE part.
The part number for the longer end link is P/N:85590925
Edited by MisterEhEDC
Have a 2020 rst Bilstein 6112 at 2inch made 1/2 spacers where the sway bar  bolts to frame to lower bar so to not put to much stress on the links. No Rubbing.  Gm parts direct has them for under 20 dollars a link under that part number 85590925 you posted. But if I search 2020 TB vs No TB both come up with the same part number 84367821. The sight won't give sway bar link parts numbers for anything 2022 and up. What year truck did you crawl  under?
  • 3 months later...
On 5/24/2023 at 5:09 PM, Jhmm712 said:
What size lift in in your truck for the sway bar link to hit the axle?
I put a 3inch lift in my 2021 no TB and my sway bar hits my cv axle also.
I have the front leveled 1" and it's a TB. So we should be around the same.
  • 6 months later...
So you did install these end links on your 2020 with no issues? I am having the same problem with my 2021 RST z71 with RC3.5” and thinking about trying this for the solution but can’t find much confirming they are compatible.
  • 3 months later...
So thanks to the Facebooks, was pointed to this page. 20 rst at 50k, 5100 front set to level. Noticed a rubbing noise while turning right, and randomly other times, but predominantly right. Seems like this might be the fix so ordered the longer ends and fingers crossed.
OMG, I'm sorry for the late reply. Yes, they bolted into my factory swaybar and A-arms.
Hopefully it fixes it for you! I imaging you'd see marks on the cv axle like in the pics if this is the issue.
Reply to this topic...
