Help with p0455 2019 tahoe 5.3
I am aware im posting for a 2019 in a 2018 subforum. The tahoe runs a year behind the trucks. I have a 2019 tahoe 5.3 that just gave a p0455 code. Mass evap leak. I do have a upr catch can installed but I don't think it is the culprit.
The only symptoms the truck has is a slight mileage drop and a smell in the cabin of used oil that comes and goes.
I do not have issues filling the tank with fuel, no gurgling or anything.
I did order a vapor can purge solenoid that installs near the throttle body just to have a starting point.
I have not seen any loose hoses.
Is there a repeat offender that causes this code?
Where else should I look?
Large leak would be a damaged EVAP canister, stuck open EVAP vent valve, stuck closed purge valve or blocked purge line.
Ideal thing instead of throwing parts at it is a scan tool and a smoke test.  Smoking the system and then commanding the vent solenoid and purge solenoid would verify their operation.  It can also pinpoint a leak elsewhere say the fuel sending unit, the top rusted and a hole opened up.
Edited by newdude
12 minutes ago, Jeremy Stephens said:
Thanks, I appreciate the help. Is there a decently affordable scan tool for this application?
Around $1000 for a good bi-directional diagnostic tool.  There might be some in the 600-800 range but not sure.  Smoke machine, not cheap.
Or its $150-200 for a shop to smoke and diag it.
Edited by newdude
