Headlight stock on
Anyone run into their headlights stuck on high beam?  Can’t turn them off. High/low switch works as it should with the high beam indicator but they stay on, If I turn the lights off the running lights turn off but the headlights stay on high beam.  Will do this for a day then next day no problem. Went into a store one day and right high beam was on and left low beam but when I came out of the store both on high beam.   Any help. I’ve changed the relay.
That's different for sure.  If you find a cure to this problem you are having please let us know.  @Pryme keeps records to help others in the future.
Edited by Jettech1
Happened to me last week.  What made it worse is I have LED's mounted behind my grille connected to the high beams.  I was able to get the driving lights turned on and that deactivated the high beams.  Next time I started it up, no issues.
    247.7k
    2.6m
    Tybo8823
    Tybo8823
  • Who's Online   5 Members, 0 Anonymous, 1,315 Guests (See full list)
