Need help finding out what's up with my suspension
In your #2 post you stated you didn't know if the truck was lifted and now you seem to know it all and are giving the 1 guy who took the time to try and help you a hard time. AMF, the  Forum will be better off without you, Good luck with your truck!
  • Thanks 1
On 1/25/2023 at 10:50 PM, Sum Sum said:
Well you have better info then that other dude, figured I'd have to swap out the lift kit on it.
Has the truck been in a wreck before? Looking at the lift and the upper ball joint, it looks improperly aligned and it looks like too much space between the upper arm and the lift spacer, leaving a  lot of ball joint shaft to take the abuse. I could see where it could snap off. I just re-read about your upper arm rubs on tire. It's almost like your upper BJ is "too tall". It's pushing the the upper a-arm up so high causing it to hit the tire. A-arm should be about even with the rim. Without being there and looking it over, that's about all I got. I found 3 people with similar issues, actually 1 had the exact complaint, and they went to another kit that had more pieces to change the necessary angles
Removing the lift and looking at some things is the way to go. Is the other side exactly the same?
Best not to call people names, again not helpful getting people to want to help you
Edited by txab
sp
  • Thanks 1
10 hours ago, Sum Sum said:
Dumbass can't even spell patience. Over this ****** forum with no one that can help.
Hum imagine that. I made a typo. Can someone call 911? The world is ending!
:crazy:
I wasn't speaking to you.
Was I?
:idiot:
20 hours ago, Sum Sum said:
So, (comma required) I bought this truck awhile (a while) back and been (have) slowly fixing (fixed, verb tense) her up and (delete and use a comma) now run into a stall and can't figure it out. I've gotten several pairs of front shocks and no luck between (delete word) getting them to fit length wise (length-wise) and into the slots where the top and bottom bolts go through. New to the whole 4x4 scene and just (delete word) wanna (want to) fix up this thing.
Now I am.
@txab...sorry, I fed your troll.
He didn't have a collar.
14 hours ago, Sum Sum said:
Oh my goodness your so smart, I don't know why I didn't think to look it up on Google. Now how about the several pages of stuff that has lead me nowhere hence the reason I'm on here looking for help. Obviously your just a troll so unless you can help then refrain from any further unnecessary comments.
Just go away.
  • Thanks 1
  • Haha 1
