2019 Sierra Rear Pad & Rotor Replacement
1. Engine OFF
2. Electronic parking brake also  OFF
3. hold the push-to-start button to get accessories mode on. Or if you have the key ignition  🔑 turn it half way before starting the engine.
4. hold brake pedal and electric parking for 12 seconds  then let go at the same time.
5. quickly press the electric parking brake button once more then let go.
you should be in the brake service mode after a couple tries. You’ll hear the noise and the yellow light on your dash blinking etc.
Only after you do this then change your brakes in the rear. I was easily able to push in the piston and install my news pads.
if you remove your brakes and caliper first then do this procedure your piston will fall out and it’ll take you hours to get it back in without damaging the the seal. Ask me how i know.
POINT BEING IS get the truck into brake service mode first THEN doing the rear brakes is to easy.
Edited by 11bravoZ71
