2019 Silverado 1500 LD Rear Window Wind Noise
RandyR
My 2019 Silverado 1500 LD (solid rear window) has wind noise that appears to be coming from the right (passenger) side near the top of the window.   I've seen others report a water leak in that area and I'm not experiencing that (yet) just the wind noise.  I thought about running a bead of "Mortite" caulking cord around the top and sides of the window, but don't want to create a worse issue by potentially trapping water along the top ledge of the window.
Anyone have ideas on the fix for this?
Thanks!
I found the cause of the wind noise:
The entire lower edge of the rear window is not attached to the body.  When underway, there's 1/8 - 1/4" gap between the window and the body.
How to fix this is the next question...
