Nitrousbird Posted December 20, 2022 Share Posted December 20, 2022 Late build 2018 with 20k miles. The backlight on the AC button likes to flash. Will do it while driving, will do it while parked, will do it whether I push the button or not. Sometimes it will be solid, sometimes totally out, but mostly flashes on and off. Besides replacing the who HVAC control panel, any reasonable fixes for this? Annoying. No other buttons have this problem. Quote Link to comment Share on other sites More sharing options...
JimCost2014 Posted December 20, 2022 Share Posted December 20, 2022 If it is flashing 3 or 6 times, you have a problem somewhere. Could be a bad ground on the HVAC controls, ambient temp sensor is bad, low on coolant, problems with the HVAC system itself, ect... Not sure if just a new control unit will fix this one. Quote Link to comment Share on other sites More sharing options...
Nitrousbird Posted December 21, 2022 Author Share Posted December 21, 2022 22 hours ago, JimCost2014 said: If it is flashing 3 or 6 times, you have a problem somewhere. Could be a bad ground on the HVAC controls, ambient temp sensor is bad, low on coolant, problems with the HVAC system itself, ect... Not sure if just a new control unit will fix this one. Totally random flashing. May stay out for several seconds, be solid for a while, flash in and out quickly or slowly. Nothing that one could indicate being some type of trouble code. Quote Link to comment Share on other sites More sharing options...
tbarn Posted December 22, 2022 Share Posted December 22, 2022 New controller fixed mine. (2018) 1 Quote Link to comment Share on other sites More sharing options...
