My trio of GMs
16LT4
For a nearly a year, I kept my ‘70 VW as a station car 200 miles away for work. I brought it back to my house this past Spring to swap chassis, redo the interior and reupholster the seats, swapping it with my ‘84 GMC. Both were driven each way. 😎
The truck’s carb gaskets started leaking enough to smell and see fuel, so in October I swapped on a Weber 38 in place of the original 2SE. Unfortunately, that carb seems to be bad out of the box to the point I’m sending it back; I’ve only had an hour or two every few weeks to work on it, hence it now being December and it not being done yet.  It also had developed a copious front crank seal leak. So, it had to come back to my shop. But, I already have 5 vehicles there and didn’t want a 6th, so one had to go… queue the K2.
The 442 drew the short straw… or rather the only straw. Which is fine, because it was mostly sitting for a few years, so now it’ll actually get driven, which is a good thing. Once the S15 gets back home, it’ll get a new timing chain, sprockets, all oil gaskets, distributor o ring, front crank seal, clutch, and possibly RMS. When I pull the pan I need to see which one this has; if the 1 piece, I’ll have to pull the engine and the crankshaft to replace the RMS. Its underside is 38 yr old black undercoat, no rust.
The Olds weighs 3600-3800 lbs plus a full tank of fuel, and the trailer is 2k lbs. IIRC. The S15 is under 3k lbs. As we all know, the 5.3 did fine. Unfortunately, I had to pick up the trailer and load the Olds in a snow storm, a little sketchy with trailer surge brakes, and now the Olds needs a full underside wash. Until I started hitting a strong 30kt E headwind, the truck was getting 15 mpg, kept in M5 and staying 60-65 mph. I only checked transmission temp when it was working hard(er): climbing the Taconic mountains, or NYC traffic, and only once did it hit 150*; every time I checked it was 142-146*F. I installed the upgraded T stat last year.
Edited by 16LT4
  • 16LT4 changed the title to My trio of GMs
