Blackbear tuner, e85 sensor + adapter
Yondu
I used this on my 2018 Silverado I traded in a year or so ago. You will still need credits and such from BBP
$120 shipped
Oem e85 sensor with female/female quick connect adapter. This adapter makes it so you can unplug your fuel line and put this inline. I did it by my tank. It's shorter and fewer connections over the more common method of buying a bunch of pieces.
$80 shipped (both, won't separate)
$180 shipped for everything.
On 12/9/2022 at 4:42 PM, Custom 68 said:
On the e85 sensor you were able to swap this close enough the wiring you didn't need to extend anything?
Thanks
Dave
Yes, I didn't do any wiring extension. This was at a factory fuel disconnect location.  By using the shorter connector setup I was able to keep it all tucked up pretty good.
