SILVER SLED Posted November 24, 2022 Author Share Posted November 24, 2022 3 hours ago, GETGONE said: I tried several runs in 2wd and played with air pressure in the tires. It just spun the tires and was even worse because the G80 didn't kick in for a second so you had one wheel spin before the other caught then both spun. I didn't run any in 4 high, only 4 auto. I don't know if the transfer case actually disengaged after launch or not. Try 4wd and mash the pedal, then switch to 2wd asap. It’s actually hard to reach and press the button. Where in Michigan? What track do you go to? Quote Link to comment Share on other sites More sharing options...
SILVER SLED Posted November 24, 2022 Author Share Posted November 24, 2022 (edited) This is from the draggy, the .48 run and the history of runs. The number 3 and number 2 runs were back to back. #3 in sport mode and #2 in tow/haul mode. Edited November 24, 2022 by SILVER SLED Quote Link to comment Share on other sites More sharing options...
GETGONE Posted November 25, 2022 Share Posted November 25, 2022 11 hours ago, SILVER SLED said: Try 4wd and mash the pedal, then switch to 2wd asap. It’s actually hard to reach and press the button. Where in Michigan? What track do you go to? I'd rather not blow up the system trying to switch while under full throttle! I'm just East of Grand Rapids. I run at US 131 Motorsports Park in Martin, MI. 1 1 Quote Link to comment Share on other sites More sharing options...
SILVER SLED Posted November 28, 2022 Author Share Posted November 28, 2022 I forgot I did replace the muffler with a $50 aftermarket straight through bullet muffler. Not saying it helped any, just forgot to mention it in the original post. Sorry. 1 Quote Link to comment Share on other sites More sharing options...
swathdiver Posted November 28, 2022 Share Posted November 28, 2022 On 11/25/2022 at 12:21 AM, GETGONE said: I'd rather not blow up the system trying to switch while under full throttle! Ain't gonna happen. 1 Quote Link to comment Share on other sites More sharing options...
wizard4878 Posted December 3, 2022 Share Posted December 3, 2022 On 11/24/2022 at 8:40 AM, SILVER SLED said: I’m sure there is some power loss, but the advantage of the limitless traction in 4wd and just mashing the gas pedal from a stop, seems to out weighs the loss of power. If you mash the gas pedal in 2wd you would sit there and spin the tires. So to get a good launch in two wheel drive you would have to cut the power on launch (feather the gas pedal) a lot more than is lost in being in 4wd. So in this stock truck launching in 4wd would win the race. I do quickly shift out of 4wd after moving. Now a modded 2wd truck that has less weight in front, and some suspension work done, with slicks and skinnies would start to overcome the 4wd advantage. Interesting that yours will shift from 4 to 2wd while under power, I have tried this a dozen or more times and mine will not until I let off the throttle and even then it takes at least 8 to 10 seconds to do it so by the time you launch the truck and reach down and push the button the race is over. Not doubting your word, just find it interesting Quote Link to comment Share on other sites More sharing options...
SILVER SLED Posted December 3, 2022 Author Share Posted December 3, 2022 1 hour ago, wizard4878 said: Interesting that yours will shift from 4 to 2wd while under power, I have tried this a dozen or more times and mine will not until I let off the throttle and even then it takes at least 8 to 10 seconds to do it so by the time you launch the truck and reach down and push the button the race is over. Not doubting your word, just find it interesting That seems strange. What engine/transmission/transfer case do you have? I have the two speed transfer case. Quote Link to comment Share on other sites More sharing options...
wizard4878 Posted December 5, 2022 Share Posted December 5, 2022 On 12/3/2022 at 12:54 PM, SILVER SLED said: That seems strange. What engine/transmission/transfer case do you have? I have the two speed transfer case. I have the 8 speed transmission, maybe that's the difference Quote Link to comment Share on other sites More sharing options...
SILVER SLED Posted December 5, 2022 Author Share Posted December 5, 2022 1 hour ago, wizard4878 said: I have the 8 speed transmission, maybe that's the difference I don’t know. I had an 18 6.2 8 speed and a 15 5.3 6 speed and they would also shift out of 4wd hi to 2wd at full throttle. Quote Link to comment Share on other sites More sharing options...
INTJ Posted December 25, 2022 Share Posted December 25, 2022 I wish I had run my 2020 6.2 Max tow 4WD on the strip. I had the GM performance intake and exhaust. The truck had 3.42 gears. I have owned a lot of different pickups, and have had three tuned 2500 Duramaxes. I now have a 2022 2500 HD with the l5p Duramax. I think my 6.2 would beat all the DMaxes handily when they were stock. 1 Quote Link to comment Share on other sites More sharing options...
