OEM Denali headlight swap with SLE 2018
Not sure about the 2018 model year, but previous years your BCM had to be programmed to use the headlights from the higher level trim. Not sure a wiring harness will do anything. But you could check gen5diy.com to see if they have anything. But like I said, I don’t believe it’s as simple as a harness. The BCM may require programming.
52 minutes ago, Kay11 said:
Help please, so I’ve replaced both my headlight assembly with a Yukon Denali headlights and and it’s flickering off and on because I’m sure the wiring are different. Is there a wire harness I need to make it work, thanks.
Pretty sure you are gonna be selling those and putting the originals back in.  Gen5diy makes a PnP kit for Sierra but the plugs are wired differently for Yukon.
Would be a better option to add HID or LED bulbs to the stock headlights.
