OCI, not when but why?
I read an article recently about the 10 worst oil filters. I expect Fram to be on it but Wix, Redline, about that time I stopped. It was like watching the news. Pick your channel you will get what you want. The truth well that doesn’t matter.
I haven’t found a bad oil filter except WIX that had metal shavings in them about 1995 and it was corrected quick. I think about any oil filter is fine if it meets specs for OEM. For me cheaper the better.
That’s funny in my own oil changing days if I didn’t use Amsoil filters it was Wix. Now I just go to the Valvoline quick change and more often.
Wix issue was just one off but it ruined a few 5.9L Cummins engines in Dodge trucks.
I used Amsoil in my 5.9
9 hours ago, VicFirth said:
Red Line 5w20
Noack 4%
HT/HS 3.1
HTHS of this oil EXCEEDS *W30 specs 😉!!!
What I used to run in my Honda's. 7.5K OCI's. It's also the oil I ran in Pepper the summer I got 30 mpg all summer. IF I owned a 5.3/6.2 AND was interested in running a W20 this would be the one. But as I have zero IF's or AND's......😏
Hey @VicFirth, can you find a VOA for Schaeffer's Supreme 9000 5W30?? Something with oxidation? 😉
Edited by Grumpy Bear
Grumpy, I was looking at some UOAs on the Russian Oil Club site.  They seem to claim that because Red Line contains a significant ester base, it turns acidic quickly with TBN falling and TAN rising.  Do you think there is any truth to that?  Also, what about engine seal compatibility?
I recently found this out about Red Line for what it's worth:
"Oh if you think Amsoils Lab is something... you should see P66's R&D Center in Bartlesville OK. P66's lab is huge.
Previous to P66 owning Redline, a company named Spectrum, who was an additive manufacturing company, owned Redline. P66 ended up buying them for a bunch of other assets.
The API approved Redline series is simply Kendall re-bottled. But yes, I still have faith in redline's claims. Knowing they do a lot of testing at P66's lab for years now. And previous to that, Spectrum had their own additive testing lab and engine test stands. But, you can also go directly to the additive manufacturer and have them run testing. Afton will run engine stand testing. It's just expensive - due to the low volume of the product, its why the product is so expensive."
Bound by Performance: The Lingenfelter & AMSOIL Strategic Partnership - AMSOIL Blog
AMSOIL products are now the “Official Lubricants of LPE.”
“The choice for us was performance based,” said Mark Rapson, COO/VP of Operations for Lingenfelter Performance Engineering. “The synergy from a technical standpoint is why we wanted to align ourselves with AMSOIL.
“During our R&D work, we began to experiment with and evaluate top oil brands to understand performance differences in given applications,” said Rapson. “We were surprised at the differing results and found that AMSOIL gave the best performance in our application. This led us to contact AMSOIL."
  • Like 3
What am I going to do with you Vic? :crackup:I've run this product in select vehicles in my charge for over 25 years and perhaps a million miles between them all. Not a single seal failure. Never ASH loaded a ring set yet. Doesn't make your hair fall out or give your dog shingles. I've run the 5W20 in Honda's to 7.5K miles without crossing the TBN/TAN. Yes it has a high INITIAL AN. All ester bearing oils do. It backs up a bit before heading up again. A quirk of the ester family in this service.
I don't use Red Lines base series and never looked into it. Kendall? Okay, I have no reason be believe other. :dunno:
I believe you LOL. 👍
Schaeffer VOA show oxidation levels at 10 or under.  I could only locate (1) VOA and it was Supreme 9000 series which had a virgin oxidation of 9.
Interesting. I was looking into the 0w40 version and it appears to be majority PAO based on the SDS. Must be using something other than an ester alongside it. AN seems doubtful but I dunno.
1 minute ago, diyer2 said:
Real happy with Amsoil products, no need for anything else.
Despite many of their annoying dealers, they make top notch oil.  The oxidation readings for Amsoil are in the 50-65 range.  So they're using substantial V.
  • Haha 1
