Installed the Roadmaster Active Suspension system
Hi all, this was an easy install and made a MASSIVE difference in the feel of the truck when towing and or loaded with some weight.
After a QUALITY weight distributing hitch installed PROPERLY I feel this is the next best item to install to any towing vehicle.
Be sure and install these correctly as there are many people just putting them on the truck with the pins in the incorrect positions.
Gained 3/4 of an inch over factory while loaded or unloaded when set up on the 40% adjustment with the black feeler gauge disc.
I have noticed a little more stiffness when loaded or empty at the highest setting, but it is a negligible amount.
Hope this helps some of you to feel confident and able to do this yourself as well as give some insight before the purchase.
I ran across a few of your YT videos awhile back. Welcome to the forum!
