I went to swap out the radio in my 2014 sierra with Bose and ran into a problem. The green plug that plugs into the factory unit only has two wires in it but everything I've seen online says that plug should have most of the speaker wiring in it. Not sure where I'm supposed to plug in the harness I bought.
I put all the stock stuff back together and ever since then the radio would randomly cut out. It would lose all sound and the clock would disappear. When it would come back the HVAC controls would appear on the screen. Figuring it was a loose wire I pulled it apart to check the connections and now I have nothing on the screen and no sound. Back up camera works, fuse is good, no idea what's going on.
At this point I don't care if I just get the factory radio working or if I have to swap it out for the aftermarket one. Any insight would be appreciated.
