2004 Sierra SLE ignition cylinder replacement help
That video shows you how to remove the plastic cover at least. if you can't turn the ignition lock you may have to drill the center out to get it to turn in order to remove the lock cylinder. there is a small hole on top of the lock assembly. insert a small drill bit to depress the pin while turning the cylinder counter clockwise and it comes out. the door locks are self explanitary once you get the interior panels off
